Structural error limit
creixen
ES
Hello!
I would to know what is the limit of the structural error in Static Structural ANSYS analysis.
Whay is the best way to make sure to have achieved a good solution?
Thanks!
I think what you're asking is how to know or customize the value of the convergence tolerance. Default settings are typically good for this however if you feel the need to empt your own value you can use the CNVTOL command to do so.
