Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
projected area is just these elements shown in the picture.(just these cables and the steel posts), These results were just due to self weight.BridgeSmith (Structural) What is the vertical sag relative to a straight line between the supports? Is the 600 lb load still applied? If the 600lb load is applied, what's the projected area for wind?
[/quote]dauwerda (Structural) Based on the image posted said:https://www.powerlinesystems.com/plscaddultralite)[/URL]
BAretired (Structural) What is the reason for using three ties on each post? Why not just one at the top?]
Should I go with this results, means my design is adequate to be constructed by using cables suspended between steel posts, is it a reliable design?
Wazir said:Should I go with this results, means my design is adequate to be constructed by using cables suspended between steel posts, is it a reliable design?
BridgeSmith said:BAretired[/color]]BAretired, your "simple statics" approach may give results that approximate other analysis methods, but in order to satisfy the statics of the distributed weight of the wire, the vertical reactions at the ends of the span would have to be nearly equal, varying only slightly with the amount of the sag, approaching exactly equal as the sag decreases.
When the supports are at an equal elevation, the vertical reactions would have to be nearly equal, but when Point B is 13.5' lower than Point A, they must differ by 2*13.5H/L where, in this case, H is 4000# And L is 400 feet (statics).
At zero sag, the tension also becomes infinitely large.
I agree, and that condition is impossible.
The low point also changes significantly with the amount of sag, from nearly midspan for high sag values, to actually being at the right end of the span for low sag values.
The low point of the cable changes in elevation,but not in the position in the span. So if a tension of 5000# is specified, the sag below point B becomes 1.82' but the low point of cable remains directly below Point C.
EDIT:
Oops, typing before thinking, a bad habit. If H = 5000#, the reaction at Point B becomes 300 - 5000*13.5/400 = 131.25#, so the low point moves to 131.25/1.5 = 87.5' from Point B. And the elevation changes as well.
If H is large enough to remove the vertical reaction at Point B, the low point of the cable is at Point B and The vertical reaction at Point A is the total weight of the cable, i.e. 600#. That would occur when 13.5H/L = W/2. In this case, when H = 8889#.
Where can you confirm if wind would cause any significant effect as the projected area for wind is very small @BridgeSmith.?
