Does a Structural Engineer have the right NOT to follow a PORTION of any given applicable Design Standard / Code (AASHTO for instance, in bridge design), if he doesn't want to (because it is very detailed and time consuming)?
I know that the Design Standards (AASHTO, ACI, ASD, IBC) aren't perfect, they can sometimes be very tedious, and that they can't possibly cover every single situation, so an engineer must use common sense and good judgment in using them. However, the thought that I'm getting at is that of: “The budget only allows for a certain amount of DEPTH of design, so I will do only as much as the budget affords (with no gross omissions of design), and then stamp the design and take ownership for it.”
