Gumpmaster
- Jan 19, 2006
- 397
Is there a standard, somewhere, which says what should be included in structural calculations?
For instance, if I have a a deferred submittal where the calculations are done by the Contractor's engineer, what should I expect? I received a set of calculations that calculates all the loads for a paritcular component, but doesn't calculate any capacities and doesn't compare the applied loads to anything that would show that the component is acceptable. I know as the EOR we don't need to do a line by line calc check but we typically check for gross errors.
The problem I have is that the Contractor says that there's nothing requiring them to compare applied loads to capacities. Is there any standard which says what should generally be included in calculations?
