Mandrill22
Someone else created a formula to find the stress on one of the sheets of, what amounts to, a rectangular pressure vessel. There is always a vertical brace bar running up the middle of the sheet and, if the stress is high enough, 1 or 2 horizontal braces are added to the left and/or right side (see attachment for 2 horizontal braces).
The formula the other engineer created to find the flexural stress is:
F = PH^2 / 8Z
The formula he created to find the stress on the left side of the panel with no horizontal braces is:
S = P(L/2)^2 / 4(9.525^2(1+((L/2)/H)^2)))
For the stress on the top half of the panel when there is one horizontal brace, he put:
S = P(L/2)^2 / 4(9.525^2(1+((L/2)/2H)^2)))
Where:
9.525mm (3/8") is presumably the mat'l thickness.
P = Vacuum pressure MPa
L = Length of tank wall mm
H = Height of tank wall mm
Z = Wall section modulus mm^3
Two braces is the same thing, but with the height divided into thirds.
Are these formulas correct? I can't find anything similar online.
F = PH^2 / 8Z
Where:
