C
ctarmijo
Guest
Good Morning All,
Has anyone encountered a problem where the way a feature has been created results in large variances in an analysis performed in Mechanica? My current issue is this. If I create a feature in ProE where the sketch is external and run a simple linear stress on the member, I will get a certain result. If I then take the same model and change the same feature so that the sketch is internal, I get a very different result. Is this common? If so, what is going on and which approach is the best to take.
Please keep in mind that we are performing this analysis on an educational license at the local univerisity and this isssue has now posed itself. Thank you for your help in advance.
Christopher
Christopher
