imagineers
I am designing an enclosure for several components. Total weight of the components with fluid is around 100lbs. the box is around 427mm x 904mm x 173mm. It is a simple box with bent walls and a top bend flange for some strength, but I am a little concerned that maybe the bottom may be kind of weak. What can I do to strengthen this? I have thought about adding punched features in the bottom like ribs, or even a welded l bracket across the box, but I am not sure whether this follows any standard or will be the best and maybe most economical option??
