OffshoresMech
- Jan 28, 2009
- 4
Working on the lifting lug/padeye design. The lug is basically a steel plate 32mm thick by 500mm long by 330mm high (with an opening for attachment), and it is attached to the I-beam of the frame by a welded joint. The padeye is obviously in tension as the structure is being lifted but there is also a perpendicular component (5% of the upward force), so there is going to be stress from bending in addition to the tension in the welded joint.
My queston is, if the padeye is attched to the beam by a full penetration butt weld along the 500mm edge on both sides, can you assume the weld area to be equal to base material area, and thus don't bother calculating stresses in the weld but only the stresses in the x-section of the plate (500mm x 32mm)?
Quick search on the internet (and some thinking) points into that direction, however I also found some oposing views. And so I'am a little confused.
This is my first post, so please be patient.
Thank you.
