bookowski
- Aug 29, 2010
- 983
See attached photo. I was looking at this building for something unrelated to the framing shown.
The photo is of roof framing: 3x10s @ 16" o.c., spans around about 15ft. from walls to center steel beams. To pitch the roof the original builder built a series of 2x4 stilts off the framing which in turn support flat 2x4 (@16 o.c.) to support the pitched sheathing. These 2x4 posts vary from 0" to about 12" in height. The building is a two story brick masonry residential, late 1800s but the framing shown is obviously much newer (1990s).
My work was not related to this framing so I am wondering what kind, if any, of upgrades to the framing I should recommend - or should I leave well enough alone? The joists are obviously not braced by the sheathing. There also is an issue of the diaphragm not being connected to anything. Since this is an existing condition I don't want to go overboard and recommend major fixes if they are avoidable. I was thinking of solid blocking between the joists, providing post installed ties from masonry to the joists, and was also considering some diagonal struts up from the blocking to provide a lateral path for the diaphragm. The roof/roofing is not being worked on so ideally all work is from below and does not penetrate the roof. Any thoughts/recommendations?
