strange window behaviour in SW x64 1
dogarila
CA
I have some VB programs and some VBA programs to help me with my work. They worked fine in SW2009 x32. After I upgraded to SW2009x64 (Windows XP) they started this annoying behaviour that the window they open goes to the bottom of the windows on my screen and I have to dig for it. Same behaviour in SW2010 x64 on Windows 7. I checked one of Tick's programs and it does the same thing. Has anyone encountered this problem and has a solution? I have SW2009 x64 installed at home on Windows Vista and don't have this issue.
I have seen the same behavior exactly as you have stated. I just learned to use the windows button + tab button and select the macro window. I am on windows 7, sw2010 x64.
This is a major PIA for us using Win7 64 bit. I'm not in any hurry to "upgrade" my home XP boxes...
so you trying to say you are running 64-bit application on a 32-bit platform? if so, may i ask why?
ws000 - One can't install and run a 64-bit application on a 32-bit platform.
Thanks gopack13 for the link. It needed a little tinkering but I got it running. I had to declare the functions private and remove "Global" in front of const.
Code:
Option Explicit
Private Declare Function SetWindowPos Lib "user32" _
(ByVal hwnd As Long, ByVal hWndInsertAfter As Long, ByVal x As Long, _
ByVal y As Long, ByVal cx As Long, ByVal cy As Long, ByVal wFlags As Long) As Long
Private Declare Function FindWindow Lib "user32" Alias "FindWindowA" _
(ByVal lpClassName As String, ByVal lpWindowName As String) As Long
Dim res As Long
Dim lRet As Long
Const SWP_NOMOVE As Long = 2
Const SWP_NOSIZE As Long = 1
Const FLAGS = SWP_NOMOVE Or SWP_NOSIZE
Const HWND_TOPMOST As Long = -1
Const HWND_NOTOPMOST As Long = -2
and in main() or form_load() in my case, right at the end:
Code:
lRet = FindWindow(vbNullString, UserForm1.Caption)
res = SetWindowPos(lRet, HWND_TOPMOST, 0, 0, 0, 0, FLAGS)
I have had this problem with SW2010 and 2011 on both Vista and 7 x64.
This is sofar my best solution.
Every time i have a messagebox i then have to redo it.
Code:
swApp.SendMsgToUser2 "Bla bla", swMbInformation, swMbOk
UserForm_Layout
Code:
Sub SetTopMost(sCaption As String)
  Const FLAG = SWP_NOSIZE + SWP_NOMOVE
  Dim hWndForm As Long
  On Error Resume Next
  hWndForm = FindWindow(vbNullString, sCaption)           'get the handle of the userform
  Call SetWindowPos(hWndForm, HWND_TOPMOST, 0, 0, 0, 0, FLAG)
End Sub
Sub UnsetTopMost(sCaption As String)
  Call SetWindowPos(hWndForm, HWND_NOTOPMOST, 0, 0, 0, 0, FLAG)
End Sub
and then in the form i add
Code:
Private Sub UserForm_Layout()
  SetTopMost Me.Caption
  UnsetTopMost Me.Caption
End Sub
This is the only way i found to bring the form to front and still not lockup solidworks totally afterwards.
