Greetings,
I have a customer whose pump we've overhauled, its a 9 stage boiler feed Sulzer MD 100-300. I wasn't told until now, but we received the pump with a pair of bearings that had been badly wiped. Now we're wrapping up the overhaul and the customer shipped us the spare journal bearings they'd like for us to install.
The coupling end bearing is a plain journal bearing, split geometry with oil grooves at the split line. The thrust end bearing has four grooves in the bearing surface, each 90 degrees apart. Both are oil ring lubricated. I've never seen a bearing like this and I'm thinking it was made this way to lower the bearing stiffness and allow the shaft to find equilibrium using mostly the wear rings and balance drum centering forces (Lomakin effect). A picture is attached.
Have y'all seen anything like this before? Seems like the bearing is just allowing the shaft to whirl in the clearance due to it being virtually unloaded. We sometimes have issues with multi-stage pumps where the bearings end up lightly loaded; our solution is to up the specific load by lowering the bearing L/D ratio (shorter axial length). Never have I seen this arrangement, and the customer claims they've gotten a good reliable run of the pump (~2 yrs), but I'm weary of putting this back into their pump and offering a warranty.
I've heard tell of the mystical four-lobe bearing but never seen them in action. I'm pretty sure I'm not looking at one here though, at least not a proper four-lobe. The clearance is circular, no clearance preload or pad offset (we took a FARO arm to the bearings, they are plain cylindrical).
Let me know what you guys think. I think I'm just looking at a goofy bearing that the OEM decided didn't need real bearing features for the pump to run fine. 2 years of run-time is not amazing, somehow it feels like we're going backwards in our expectations of reliability.. maybe a thought for another time!
