Strand7 - adding a torque or moment
bigbal
4
Hi there Im new here and was so frustrated by this problem i thought i would join this community.
Basically I am trying to model torque on a shaft using brick elements with linear static analysis. Very simple in any FEA package but Strand it seems. I am fixing one end of the shaft, and applying a moment to the other end's nodes. The moment arrows display as they should, but the solver fails when run.
Can anyone help?
Brick elements in Strand7 (like many FEA programs) do not support rotational degrees of freedom at the nodes, so you have to model the torque using a statically equivalent set of forces, not nodal moments.
It does not make sense to add a moment to the node of a brick element (as jhardy said). What other FEA package are you referring to?
One common approach is to the connect a "wagon wheel" set of beams to the nodes of the solid elements. You can then apply a moment to the center of the wagon wheel. This will translate into a set of equivalent forces to the solid elements.
Brian
An alternative to applying equivalent nodal loads is to create a node on the centre line of the shaft and connect it to edge points with rigid links. You can then apply a moment to the new node.
Doug Jenkins
Interactive Design Services
I was referring to Solidworks simulation. It seems easy in that package to apply a torque to models of tet. elements.
Thanks all for the suggestions.
