Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Introduction
MECHANICAL BEHAVIOR at high strain rates differs considerably from that observed at quasi-static or intermediate strain rates, and many engineering applications require characterization of mechanical behavior under dynamic conditions. For example, strain rates ranging from 100 s-1 to more than 104 s-1 occur in many processes or events of practical importance, such as foreign object damage, explosive forming, earthquakes, blast loading, structural impacts, terminal ballistics, and metalworking.
This introductory article briefly reviews the dynamic factors and experimental methods for high strain rate tension testing and compression testing methods listed in Table 1. Considerable data on the high strain rate behavior of many materials (including steels, aluminum and copper alloys, titanium, beryllium, magnesium, and zinc) are available in the literature (see the Selected References at the end of this article). Results indicate that for many metals a linear relation exists between flow stress and the logarithm of plastic strain rate in the range from quasi-static rates to about 103 s-1. Above this range, however, the flow stress generally rises far more rapidly with strain rate. Thus, the linear relationship is no longer valid, and extrapolation from the lower strain rate regime becomes unreliable. Fewer data are available at the higher strain rates, particularly at very high strain rates above 103 or 104 s-1, at which testing becomes more difficult. At strain rates in excess of 104 s-1, the lower yield stress is often found to be directly proportional to strain rate, rather than to the logarithm of strain rate. This implies a new region of mechanical response controlled in part by a viscous damping mechanism in contrast to thermally activated processes at strain rates below 104 s-1.
