hello - i have a leveling plate that will be made from a36 h.r.s. that is to be used to level 3 pads for a table - the plate is only 2mm thick - not machined either side - i want to hold some type of datum so that the plate can be made straight or flat - shims will be used on top of this plate to achieve the correct level after it is installed - any help would be greatly appreciated - thank you - plate is roughly 960mm x 860mm
