STP Export Error
adam1986
Industrial
GB
NX 8.5.3.3
When exporting STP files i get the following error:
step203ug.exe - Entry Point Not Found
I have tried STP203 and STP214, both fail to export with the same error
I have also tried other parts....
I can however export these parts on a different machine, so im assuming its a local error?
The only other issue i can see is that Virus scanners think its malware, so put it in isolation, but i doubt thats the case in this instance.
Thanks in Advance
Adam
I think you should call GTAC on this. It's either a poor install, or something that Gtac can help you sort out.
Tomas
