RjMelbourne
Colleges
I have been asked to calculate the discharge of a 25 ha rural catchment and compare it to what the local authority has on its data base. Based on my calculations trunk drainage will be designed and my client will be able to claim reimbursements from the authority. I have done so how ever I am not happy with the answers I have computed.
Below is what I have done and a description of my catchment area. I would appreciate any feed back on if you feel I have gone the write way or if my model needs a calibration.
CATCHMENT
Area:- 25ha
Average Slope 2.0%
Length 750m
Large field with grass up to 30cm high
My area has no contributing area above so I have assumed that the top of my field will sheet a maximum length of 200m (as allowed in local authority manual) to calculate my tc for sheet flow I have used Friends equation of tc = (107.n.L0.333)/S0.2 . For this I used a Horton's retardant factor of 0.045. This gave me a sheet flow time of around 19.5 minutes
I have then assumed after the 200m of sheet flow my discharge will become stream flow and used the Kinematic wave equation. tc = 6.94.(L.n)0.6 / (I0.4.S0.3) with a retardant factor of 0.2 as detailed in the Australian Rainfall and Runoff guide 1987
How ever as your aware this formula requires the input of a Intensity in mm/hr. To calculate my I0.4 to use within the kinematic wave formula I did the following
I = I0.4
I0.4 = 6.94 (L.n)0.6 / S0.3
there for I = time (min) x I (mm/hr) 0.4
Based on the intensity table for my area gave me a tc of 90 min and Intensity of 36.6mm/hr to use within my formula, with this information when I calculate my kinetic wave equation this gave me a tc of around 83.5 min.
I have then added the 19.5 min from my previous sheet flow calculation and come the the conclusion that the tc for my catchment is 103min. I have then gone ahead and proceeded to calculate the run off using the rational method of , flow = C.I.A / 360
For my intensity of my rational calc I have used 105 minutes as this is a standard ARI tc and is the closest to my calculated tc of 103 min. (I should noted the next standard ARI tc is 90 minutes)
With all of the above my figures calculated that the run off of the catchment was 1.7m3/sec. This seems very low to me. I understand that the catchment has a flow length of 750m and based on the tc of 105 minutes the storm intensity is very low, Plus a catchment of the characteristic will has a large pervious area and will absorbed allot of water but for a 100 year storm I feel discharge is very low.
Based on the above does anyone have any comments or can recommend any calibrations
CATCHMENT
Area:- 25ha
Average Slope 2.0%
Length 750m
I = I0.4
