Although lining is generally used for sanitary lines we are considering lining a storm drain to prevent leaking. An adjacent utility is concerned that storm water is infiltrating their system. I would assume that the process is the same as for lining a sanitary line.
We may have heat issues here because of the proximity to a steam line. Does anyone know if the cured liners are thermo-setting ,i.e., once they are cured they won't "melt" back to a plastic state?
