XR250
- Jan 30, 2013
- 5,970
I am doing the light gage design on a structure with storefront systems as shown (see attached). As you can see, if I frame up cripple studs under the window, there is nothing to brace my sill track on the left side. Usually, the EOR has specified cantilevered tube steel to brace the sill, but not on this job. I could cantilever up some cripple studs using moment clips at the slab but these are expensive, labor intensive and the stiffness is questionable. I am thinking about just throwing it back in the storefront supplier's lap and having his system provide bracing for the left end of the sill. Thoughts?
