I would appreciate your experience regarding the following situation
Context:
We have a 260 kW (380V) motor which is fed from a VFD. Motor moves a pump for gasoline export through a 50 km pipeline.
The motor has 2 PTCs that according to the VFD's manufacturer should be wired to an "additional board" and not to "normal analog inputs" because the motor is ATEX (IEC Ex "nA" - to be used in Zone 2)
Reading an "ATEX manual" (attached) that the manufacturer sent, it seems that this "additional board" is intended to trigger the STO function of the VFD.
For which I ask myself: is this function necessary? Or can the motor stop freewheel?
Is there another reason why you think that an additional board would be needed?
Thanks in advance,
Juan
JBC
"The more I read, the more I acquire, the more certain I am that I know nothing"
Context:
Thanks in advance,
Juan
JBC
