Stiffness Reduction - Sustained Load
Lazzaroni
Can someone clarify the Beta-d factor for reducing the member stiffness due to a sustained lateral load per ACI-05 10.11.1 for a non-sway frame?
It states that Beta-d is the ratio of maximum factored axial sustained load to maximum factored axial load associated with same load combo.
Is the sustained loading simply dead + sustained lateral load?
I would probably add in something along the lines of 20% LL (maybe a little higher if partitions are included in LL).
