Dear friends,
If I take the stiffness modifier as follows in my analysis model as prescribed by IS:1893:2016 (Indian Code)
Column: 0.7 Ig
Shearwall: 0.7Ig ( not specified in Code)
Beam: 0.35 Ig
Slab( thin shell in ETAB model) : 0.35Ig ( not specified in Code)
I will design all the structural members for the forces, I get using above analysis model.
Then if I have to check the deflections of slabs and beams to verify that whether they are within the limit specified by IS 456: 2000, Can I use the same model ( as above) or I need to have a different model with other stiffness modifier values?
Also when we define the slabs as a thin shell, the forces in beams and columns are quite different than defining slab as a membrane, what should be the correct approach for slab modeling?
Hiren G. Desai
Column: 0.7 Ig
Beam: 0.35 Ig
Hiren G. Desai
