stiffener rings
picasa
128
A tall 304SS vertical tower is to be rated for Full vacuum external pressure. Stiffener rings are required per calculations.
If stiffener rings are not allowed on the O.S., can they be put on the I.S.?
If they are on the I.S., do they have to be continuous?
Please refer to relevant sections in the code.
Please refer to any publications on this issue.
Please refer to any relevant threads on this topic on this website.
Do you not have a copy of the ASME code? If not, you need to get a copy, even an old copy will be more help to you than none.
Yes, you can put them on the inside.
Yes, they are continuous, as far as I've ever seen, just don't have to be continously welded on.
ASME code Section VIII Div 1
UG-29 & 30, UF-5, UHT-28, 29 & 30, UCS-29
That outta about do it.
Brian
