Stetter motor
Robby2000
Aerospace
Oct 29, 2024
1
hi, i'm trying to set a stepper motor in Adams view, i have a problem with the angle that the motor have to reach, i give to it a set of target angle and the time, but the motor doesn't follow my data input and has a piecewise pattern for the angles.
please export the adm file and acf and then post them here. Nobody can deduce anything from whta you have said so far.
Check input data format, ensure that the target angles and corresponding times are correctly formatted and inputted into Adams View. Any discrepancies in the data format can cause unexpected behavior. Check the interpolation settings as well, verify the interpolation settings in adams view. if the motor is following a piecewise pattern, it might be due to the interpolation method used. Try adjusting the interpolation settings to achieve a smoother transition between target angles.
Thanks ChatGPT
