I have a project where I am sizing the steam inlet piping for steam sterilizers, autoclaves. I know how to get the appropriate diameter piping that I need using the mass flow rate through the pipes and my acceptable line velocity limits.
What I am hung up on is accurately calculating the amount of steam that is required to heat the loads. The maximum steam requirement will be in the initial heating phase, when the chamber is taken from approximately room temperature to its operating temperature. There is a set amount of time this must be completed in so I can calculate my heat requirement from the mass of the chamber and its properties (specific heat ect).
My first thought on how to get the steam requirement is to look at it as an open system and use an acceptable change in enthalpy of the steam. I know it is coming in at basically a quality of 1 (at the least its .98). Where I am stumbling is what kind of exit quality I can use to accurately depict what is happening.
Thanks.
Thanks.
