I am designing a pumping system for purpose of sterilization of small water systems.
System will basically contain a 100l tank - boiler in which water is heated to 90 C, and a pump to run heated water through the pipes.
Piping is 1'' dia, so I guess that the 1 l/s flow is ok.
Cavitation is an issue, and for this operating temperature I will have to select appropriate pump.
Any reccomendations or guidelines??
