Stepper Motor or no Stepper Motor
muradovtkm
GB
Hello All,
I am designing a small project and I was thinking about using a stepper motor. I needed the motor make fixed amount of full cycle rotations (360 degrees) 6 times.
Can I program a stepper motor to make 2160 degrees or is it just 360 at max?
Thanks in advance for any help!
Steppers are not rotation- limited.
The part you program is not the motor, but the motor controller.
Mike Halloran
Pembroke Pines, FL, USA
Usually you drive them with a microcontroller and as Mike sez it then becomes the programming that controls exactly how far you want it to turn.
Keith Cress
kcress -
