hi guys, recently ive been dealing with l298 stepper driver and using a l297 to control it through a 8 bits MCU in order to develop a small movement control system. the motor consumption is 1,2 A. power supply is 12vdc
i found two problems when testing:
1. when inserted an amperimeter (multimeter) to check the current, the stepper motor delivered more torque than if i dont use the mmeter to make the measurement.
i supposed that was because bad filtering at the supply. then i filtered using a choke and capacitors. i got the same result. unfortunately at this moment i dont have a scope to view the signal. i think it is not the supply. maybe the amperimeter is generating spikes but im not sure.
2. the l298 rises the current consumption but its temperature is just warm; it rises about 0,1 A per second. i always turn off circuit when near to 2 A sems to be a unnatural runaway. the L298 is not defective, nor the motor.
any tips?
regard
killa
any tips?
regard
killa
