sprintcar
- Oct 16, 2001
- 763
About 2 years ago I made a spreadsheet to calculate shaft stiffness and the L3/D4 values along with total weight and mass moment of inertia. Works fine.
I'm going from straight shafts to stepped shaft design with different diameter/length segments for bearing fits, etc. Here's where I'm having a brain cramp and need a bit of assistance.
To calculate overall shaft torsional stiffness, are the individual shaft segments summed and averaged, or is this a series spring calculation? A non-calculus solution is preferred.
If anyone has an existing spreadsheet, it would be appreciated!
"If A equals success, then the formula is: A = X + Y + Z, X is work. Y is play. Z is keep your mouth shut."
-- by Albert Einstein
