JStephen
- Aug 25, 2004
- 8,700
Is there some standard way to handle the transition area in a stepped footing/foundation?
See the attached pdf. Footing shown could be round or square, reinforced concrete.
Summing moments about a centerline as in Section A allows you to solve for steel tension and area, concrete compression, etc., and all is well.
Summing moments at Section C does the same for the reduced section beyond the step.
The problem is at Section B. The cross section is similar to Section A, but obviously, near the edge, you can't support the concrete compression at the upper surface.
A similar issue would arise if the transition were sloped.
Various handbooks and textbooks in the office mention stepped or sloped footings, show diagrams of them, but neglect to mention how the step itself would normally be addressed in the design. Google turns up similar references that also omit details of how to handle the step.
Any input or references would be appreciated.
