Someone recently told me this:
"Want to see how bad your suspension really is? Go to an empty, flat, level parking lot, turn the wheel lock to lock in one direction. Proceed forward for a few feet, open your door, place a quarter on the ground. Close the door and proceed in a circle around to where you began. Open the door to retrieve your quarter … you’ll see how terrible of a circle your suspension is really capable of – the quarter won’t be anywhere near where you first opened your door to place it."
This orginated from a discussion about body roll and weight transfer (body roll does not cause weight transfer other then a very small amount from a lateral shift in the location of the center of gravity). Anyways, I don't see how any of that has to do with the suspension. My first thought when reading this is that of course it wont go in a pefect circle. The radius of the turn you make is dependant upon speed. You are starting out at 0 mph and accelerating to some speed. That alone will cause you to not end up in the same location.
So, my question is, if you are driving at a constant speed with the steering wheel at full lock, will you go around in a pefect circle? This is assuming a level surface with no bumps or changes in surface to cause bump/roll steer. It is also assuming a relativly low speed where are you arnt sliding around.
