I have a one story 50' X 86' building with 22 ga type roof deck on steel bar joists at 5'-6" o/c and spanning 50 feet. I designed the metal deck roof deck diaphragm and it can tranfer the lateral loads to the shear walls on each end. My chord force for the diaphragm is 4.2 kips. I am using the steel roof beam at the perimeter of the building to act as the chord member. How do I check the tranfer of the chord forces from the roof deck to the steel bar joists into the steel beam? Can the force be transferred directly from the deck to the joists to the beam (every 5'-6"o/c) or do I need a continuous angle secured to the deck and beam? The roof joists sit on top of the roof beam leaving a 2 1/2" gap between the top of the beam and the bottom of the roof deck.
