Steel post base plate on top of double bottom plates (Stupid question I should know the answer to)
Signious
Industrial
Oct 21, 2014
221
I have a homeowner who is looking for signoff on a job post-work.
-Off the shelf steel post supporting a roof beam, interior application (lean-too shed off the side of his home)
-Steel post is in the wall framing (for some unknown reason he just wants a steel post even though a 3ply 2x6 works like a charm)
-Baseplate of the post is sitting on the bottom plates
-Compressive strength of the bottom plates check out for the load from the base plate
-Conc. pad footing under post checks out
Is there a problem with this? I can't find any code specific violations (Canada Building Code 2015); the steel and wood checks out mechanically.
No objections here other that it seems silly to use steel when wood would do. The wood would perform better thermally I'd think.
Thanks Kootk, it is just a goofy situation and something seemed off about it. Im guessing he is just stubborn and already spent a load of money on the steel post.
Edit: We are talking a Wesure WS2.5 with a full saddle head btw. 50kip post to support an 8000lb load at an ~8ft height.
