our specification requires steel pipe for water supply to be designed to AWWA M11.
I understand that this allows a maximum stress of 50% yield for working pressure and 50% increase (up to 75%) yield for surge pressure.
The designer is designing to ASME B31.4 with a design factor of 0.5 and states thatthe maximum over pressure allowed for transient events is 10%.
However, he appears to be mixing AWWA and ASME standards. (I work with British Standards and don't have access to ASME)
1) Are AWWA M11 and ASME B31.4 compatible? 2) is a factor of 0.5 and a surge allowance of 10% not over conservative?
If design is to ASME should he not use a factor of 0.72 for working pressure and allow 10% over pressure for surge?
Pipeline is a buried cross country water transmission pipeline.
