reploglejj
Just joined this forum hoping to get some input from someone who has some experience about this topic. Brief intro, I am a mechanical manufacturing engineer co-op at a stainless steel mill. I work in the hot plate area where we get plates from the melt area already rolled and cut into sections. We then reheat them in a furnace and immediately quench them in a cooling chamber to harden. I've done the research and understand the theory behind the process but there's an issue the area is having with plates deforming more than they have in the past.
The plates have always had some deformation from the hardening process and that's why the next step is a leveling process. But from what I've been told its a lot worse now to where sometimes its too much for the leveler. The plates are getting extreme "crossbow" across the width of the plate. I have also noticed that thicker plate (usually around 1") seems to bow length wise so bad that it gets hung up op on the roller lines. Its bowing down and causing the plate to have one large arch.
Getting to some details about the quenching process, I am completely new to this process and still learning every day but the cooling chamber doesn't seem "ideal." I've seen videos of other mills that have a giant tank the a crane lowers the heat treated plates into to uniformly quench them. Our chamber has a system of headers above and below the plate with full-cone- spray nozzles designed for this purpose. I have been given the task to research some other brand of nozzles and figure out which have the most uniform coverage but I worry that the problem is deeper than that. I've searched and searched for information on this topic and all I can really find is the basics : "if the quenching is not uniform, the steel will warp", "if the quenching is too severe, it could change the dimensions of the plate", "but if quenching isn't strong enough to cool the plate down quick enough, it may not harden."
My main questions:
1. Why is the thicker steel bowing down? Cooling off the bottom at a slower rate than the top creating uneven heat transfer?
2. In general how does the heat transfer rate in the steel define how the plate will deform? I know there's going to be deformation with the structure of the steel changing but I just don't know what would cause the extreme dimension changes.
If anyone could point me in the right direction of where to find the answer to this I would greatly appreciate it. I know its next to impossible to figure out just by what I've typed and not seeing more but I'm just looking for ideas on what could be going on. Thanks in advance!
My main questions:
