markthefabricator
- Jun 28, 2022
- 4
Hi all,
i am looking for some advice and information on if my project does, or does not, require a P eng to be involved in it.
Context:
I run a steel fabrication and welding shop, we build a variety of stuff, mostly for heavy industrial clients. also, we do some structural steel, and we are CWB certified (Canadian certification to weld structural steel)
often, the client will dictate if a project is to be engineered or not, or it is obvious one way or the other (client says produce a stand like in this picture, it needs to hold 25 tons and its 20 feet tall = obviously getting engineered) vs (produce another one of these desks, it needs to hold a workers tools and notepad = obviously not engineered)
this project is a bit harder to call for me. it's a catwalk, on an industrial site, needs to be 28 feet long, 11'6" tall, and 3 feet wide. needs a staircase off of 1 side, and a little extension off the other (2' long, 3' wide) so crews can get closer to an actuator in their work.
i am confident i have the abilty to overbuild this and put up enough cross bracing and anchor it into the concrete well enough it'll be fine. but my question is, at what point do i need to involve an engineer? i'de had the engineering scope quoted at 7k, and dont see the need to spend the cash.
looking forward to knowing when i need to call in the pro's and when i can rely on my own judgement.
Context:
