Ramsbeam can't be beat for simple span beams, composite or noncomposite with cantilevers.
If you're also in the market for something a little more general purpose, then RISA and SAP are both great. SAP is more technically correct and much more powerful but some think it's a bit more difficult to learn. I think it's more expensive also. The last time I checked, RISA was $1200 (a few years back) and SAP was $2000 (a very recent quote) for their base version. RISA used to have a 2D version that might be cheaper and should still take care of your continuous beams.
Although I have no proof that they're all bad, I would not design any actual building members with some Brand X program that I downloaded for cheap/free from the Internet. I would feel the need to spend so many hours checking it that I would be better off buying SAP at $2k.
If I was really worked up over price, I'd write the continuous beam stuff in Mathcad or Excel using the 3 and 4-span moment, shear, and deflection values from the AISC Manual. This could be done at home over a weekend. That would be close enough for 99% of continuous beams I've done. Then buy Ramsbeam for simple-span noncomposite and composite beams.
Another thing to think about: The 2005 AISC Spec has been released and is significantly different from the 3rd Edition LRFD Spec and in a different world than the 89 ASD (Allowable Stress Dinosaur) Spec. If you write your own, you can increase the service life by using the new Spec. If you buy something based on the obsolete stuff, then you're probably going to have to buy something else soon.
14159
