CloudSan1
- Jul 27, 2021
- 9
Steel deck/metal deck are used for one way slab because of the direction of its corrugation. When used in a one-way slab, say for example a 6m x 2m slab, the steel deck corrugation shall be placed parallel to the shorter direction and it will produce a one-way slab load distribution right?
But what if the steel deck/metal deck must be placed on a 6m x 4m slab? Will it still produce a one-way load distribution even if the dimension of the slab is considered as a two-way slab? Or will it have a two-way load distribution?
If it's the latter, is there a way to have the steel deck distribute its load in a one-way direction on a 6m x 4m slab? Thanks.
