dcStrucEng
- Feb 26, 2009
- 45
(Sorry if this question has been posted previously, but I couldn't find my exact answer after performing a forum search.)
I am designing a one-story steel warehouse-type structure per IBC 2006/AISC 360-05/AISC 341-05/ASCE 7-05. Approximate plans dimensions are 500' x 160' with a height of 40'. The roof is proposed to be steel deck without concrete infill, with a standing seam roof system over. The lateral bracing system are three SCBF (one at each end, and one in middle) in the short direction and one SCBF along one of the end walls in the long direction.
My question is whether I can analyze the roof as a rigid diaphragm assuming that I comply with the appropriate fastener layout pattern, end lap and side lap provisions, and any other rigid diaphragm requirements.
The reason why I want to assume a rigid diaphragm is because I want to be able to distribute the lateral forces and moments to my roof structure (particularly for all the different wind load cases, see figure 6-9 of ASCE 7), which in turn gets distributed to the lateral bracing system.
If I assume a flexible or semi-flexible diaphragm I don't intuitively understand how this distribution of forces and moments occurs, from the roof structure to the lateral bracing system.
Any advice/opinions are more than welcome.
