Valstone
- Oct 21, 2008
- 12
I have a 2-1/2" concrete slab that spans between fin plates at a stair landing. The fin to fin spacing is 21". There are #6 reinforcing steel bars that spans between the fin plates and are welded to the fins with a 1/4" fillet weld all around. The reinforcing steel bars are located mid-depth of the slab.
What is the correct way to transfer the shear from the 2-1/2" concrete slab to the steel fin plates. The slab can span based on plain concrete shear and flexure. I am just not real sure how the slab transfers the shear to the fin plate.
Thanks,
Val
Thanks,
Val
