JrStructuralEng
- Aug 9, 2007
- 147
I am adding 127x127x4.8 HSS to the bottom of an existing W360x33 in order to obtain increased moment capacity inreased moment of inertia.
Are there any considerations I need to take into account when doing this from a design perspective? The Beam is laterally braced. I am assuming I use the larger 'Sy' when determining the bending capacity of the beam.
Any help would be great! Thanks.
(Also is there any relatively easy way of determining minimum weld lengths along connection.)
This is probably a lame quesiton for some of you, but I have never done a built up section before.
