barrnich
- Jun 4, 2004
- 1
Does anyone have links or info about proper torque specs for bolting into aluminum. Preferably, metric, grade 8.8. Or would one recommend a lower grade for such applications? If someone could give an explanation on how to calculate it it would be appreciated also. Would it be different for different thread engagements?
Also I heard that metric bolts are designed to twist apart before the threads shear in the hole. (assuming the same material) This would not be the case for aluminum holes with short lengths, but would there be a theoretical thread engagement that will allow the bolt to break first?
Barry
Barry
