SteriliserGuru
Excuse the ignorance, but as my job is mainly electrical & its 20 years since my thermodynamics subject, I need help. The Standards Committee in Australia is proposing that steam in benchtop sterilisers (often made by boiling water in chamber, or external small boiler, or by dry heated block with water injected into a "maze") be a maximum of 3% wet. I think that one would expect about 5% by boiling it in the chamber?... QUESTION:Is there a readilly acessible & practical method for measuring this????(Chamber is generally about 20Litres & has a 1/4 threaded test port BTW). Calibration usually involves measurement of pressure & temp. Temp to +/- 0.5C (at 134-135C) & Pressure to (supposedly 0.5% @ about 2.0-2.3 BAR). I think wetness is going to be impractical to measure , & would prefer them to allocate a pressure range by which it could vary from sat. conditions, as our main problem is insufficient air removal giving high pressures, or radiant heat off the wall giving high temp measurements...
