morninglori
I have a "simple" problem that I am having trouble with. I have simplified the problem so I can do a bounding calculation.
I have a large, insulated vessel at initially empty (of water) at ambient temperature and pressure. inside the vessel is a small, initially very hot(almost melting point) piece of metal (nickel). Water (ambient temperature)with a fixed flow rate streams into the vessel. The water hits the hot metal and generates steam. The water continues to flow over the hot metal until the metal is cooled enough to not keep generating steam.
I need to determine the maximum pressure of steam in the vessel. I am not sure if it is a thermo problem or a heat transfer problem. any tips on how to solve would be greatly appreciated.
Thank you!
Thank you!
