kagadpencil
I am looking at steam table data for specific volume (ft3/lb) of superheated steam in the range 500 F to 1400 F. I am ok with data at 14.7 psi but I will like to incorporate the effect of variation of pressure. The variation is not much -- May be 2"wg at the most, do you think I should at all be worrying about the effect of variation of pressure of steam in this case ? Or should I just fit a linear curve for data at 14.7 psi between the temperatures 500 F and 1400 F and use that equation?
