I have a question about steam condensate tank for a building. 200 psig steam is supplying to the building and it will be reduced to 15 psig after the pressure reducing valve. There is only one single condensate receiver tank for the building's low pressure condensate returns and the 200 psig condensate return from the trap drip leg off the main steam line. The existing tank is experiencing water hammer or flashing becuase of the two differenct pressure condensates. What can I do to resolve this problem? Do I need two separate tanks for each pressure condensate? I have seen a lot of buildings that use only one tank?
Thanks.
Thanks.
