Quark,
Darn it any how, you beat me to the point again. Heat transfer surface is heat transfer surface. With Asvs' theory the more passes I put in the less steam it will take to make delta T, heck put in 10 passes I could cut the steam to 150LBS/HR! I agree with Quark, A single pass Hx Y feet long produces a delta T of 115 degrees, The only gain that I achieve by increasing the number of passes to produce the same delta T is the reduction in length. The heat transfer areas are going to basically stay the same, Im just putting it in a shorter package.
I'm not a real engineer, but I play one on T.V.
A.J. Gest, York Int./JCI
