I used to work for a company that performed steam blows, chemical cleaning, etc... There are basically two kinds of steam blows...high-pressure exhaustive, and low-pressure high-velocity continuous. On continuous blows, there is a device called a target inserter that allows targets to be periodically inserted into the steam flow path during the blows, without having to isolate the steam flow. They are a proprietary device that wouldn't typically be found outside of the pre-commissioning service companies (although I can steer you towards a source where they can be rented). On high-pressure exhaustive blows, the targets were mounted either on a bar that is attached to the end of the temporary pipe, or in cases wher a silencer is used, it was mounted through a short temporary spool piece that was configured with 2 square holes, diametrically opposed and covered with 2" nipple/cap. The targets (target bars) themselves were generally made of brass, carbon steel, or stainless steel, all polished to a mirror finish and depended on what the customer felt would give a good indication of his line cleanliness, depending on type of service. Steam requirements wre calculated based line service, MCR conditions, velocities achievable, and cleaning force ratios (CFR's). I hope this helps, if not, I can add to it.
CW
