steam and chilled water 1
asme3470
can someone explian how steam is used to create chilled water.
thanks
You could drive the compressor with a steam turbine or use an absorbtion machine.
Are you looking for an explanation on absorption chillers; how they work? Or are you looking for a way to create chilled water with steam?
These are not generally recommended unless you are using waste heat to make steam or you can get steam real cheap due to the inefficiencies of these type of machines.
I just designed a project with a Yazaki hot water absorption units using 2-30ton units.
I'm an old hand and absorption chillers were used mostly in hospitals where they had med temp steam (220F and up) all the time and sizes were from 100 tons on up which made them impractical for anything but large cooling loads with campus-style heating plants.
Cogeneration has caused manufacturers to produce small tonnage units which will operate from 150F-220F. Absorption now can be used for local small loads and absorption has lots of advantages.
