Ok so I talked to the hardox people. Here is what I asked :
Hello Magnus,
As discussed, here are the information on my application :
-It’s the same principle as a plain bearing. It’s a rotating pin with boundary-lubrication. A circular hardox 400 plate oscillates against another circular hardox 400 plate. The equation for calculating the absolute wear life is : t = pi*L*D*w/4*f1*f2*K*V*F where
t : life in hours
L: length
D : Diameter
w : wear
f1 : Motion-related factor
f2 : Environmental factor
K : Wear factor in/((psi)(ft/min)h)
V : linear speed
F : load
I’d like to know the wear factor K for the Hardox 400.
________________________
This formula comes from ''Mechanical Engineering Design'' by Shigley and Mischke. They provide some values for the Oiles, Polyactal, 66 Nylon, Phenol,...etc, but nothing in relation with steel. The only thing Hardox have about the wear is the Relative Wear Method. By comparing the material hardness, they can forecast what will be the hardox plate wear relative to other steels. Thus, assuming I can find the K factor for any kind of steel, a good approx. could be done. Does someone have any value for a well known steel? I can't believe I'm the first person in the world who want to know how long a homemade plane bearing with steel will last! According to Hardox, it seems to be.
Any help will be appreciate.
Thanks,
