Std.out file ????
  • Thread starter Thread starter salil
  • Start date Start date
S
salil
Guest
Hi all,
Can enybody tell me about this file I found in my srart up & cannot be deleted while session is on ?
Thanx
salil.
It's kinda like a session log.
If Pro/E bombs for any reason you can check std.out to see the fault reason..
Hello Friend,
rlsmem: memory chain is corrupt
Serious internal error; cannot continue
Yes, you are right It's an error log & above is comment from one of the files when opened in Notepad.
Here is the 2nd,
analyze_n_fold_vrtx: 3 folds at a vertex
Here is the third one,
draw_mode mode 8 error
Can you please help me to understand these errors ? & how to avoid those ?
Thanx,
Salil.
Never seen these error messages before, are you using Wildfire ??
I'm workin on 2001 version 2001200 build.
Salil.
